Considering the Flojet system for dumping at home into our septic clean out. Our clean out is behind our home and no way to get RV close to it. I saw a thing from the manufacturer that with a 3/4" hos...
The flo jet uses a lot of water to drain the tanks.. You will be doing your septic system harm by stirring up more solids then usual. These will/may get out to the leach field and cause failure..
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
