- B_O__PlentyExplorer II
KopsKamper2 wrote:
I've heard of it being used many times. Seems to work just fine. Not much different in concept than a laminate floor except it's vinyl..
This also happened to our 2007 trailer this year. We are thinking of replacing it with Allure flooring that floats. Any suggestions on that?
B.O. - KopsKamper2ExplorerThis also happened to our 2007 trailer this year. We are thinking of replacing it with Allure flooring that floats. Any suggestions on that?
- travelnutzExplorer IIGee, how I sure do love the carpet we have in all our RV's and homes! Never wrinkles, splits, or looks any different even in 20+ years no matter the temp or humidity and so warm and soft to walk on. In heavy soilable areas like below the frig, range, or kitchen sink we simply have a matching or accenting 3-4 foot throw rug or bound carpet piece. We can't stand linoleum on floors as it's either nice appropriate carpet or real teakwood. Never had a single problem in over 52 years so far! Glad we learned from our parents in the 1940's and had never forgotten what really works!
- BurbManExplorer IIIWe had a similar issue although not as bad. A small tear by the door, but mostly the waviness along the walls. The vinyl contracted so much it pulled out from under the walls and now that its warming up is not expanding back into place but buckling up from the floor. We were planning on updating anyway, so I will likely cut out the existing rather than go over it. ironic we never had a problem until we moved "south"....
- B_O__PlentyExplorer IISame thing happens every year. You will see reports of this every spring. Floor coverings are loose laid before cabinets go in, not glued down. Caused by expansion/contraction. There is no glue I know that will stick when it's below zero. Those self sticking tiles will pop up once they get real cold. Cut the old flooring out around the edges. Lay the old pieces over a new sheet of flooring and use it for a pattern. Lay the new sheet in place and put quarter round around the edges to hold it in place. Open beer and admire new floor. A couple of hours and it will save you the hundreds or even thousands dealers want to charge. I've done this with laminate also with good results.
B.O. - David_RExplorerOurs did the same this winter following a few days of -15 F lows and single digit highs.
- Deb_and_Ed_MExplorer III suspect some linoleum is "stretchier" than others?? Ours survived 20-below just fine. (Knocking on wood)
- hotbyteExplorer
Bucky Badger wrote:
Shot-N-Az wrote:
How cold does it have to get to see this kind of thing? We saw temps in single digits here this past winter, but no damage.
We got to -30 this year
OMG! I would split and ripple, too!!! - Bucky_BadgerExplorer
We got to -30 this year - Bucky_BadgerExplorer
hotbyte wrote:
That's crazy! So, the subfloor is OK on these, its just the vinyl?
I didn't rip up mine yet, but the ply seems to be fine
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
