rhagfo wrote:
Chock Full o' Nuts wrote:
pconroy328 wrote:
groundhogy wrote:
Being a professional food poisonee, I can always tell early
when it starts bubbling up downstairs. I just drop one of
those antibiotic bombs down there early, while the bacteria
is still just in the stomach. Blows it up.
Food poisoning bacteria is usually some standard bacteria
and is easily killed by a single antibiotic pill.
So I'm no Doctor but I'm willing to bet $1 this is incorrect. One antibiotic pill (exlcuding perhaps Azithromycin) isn't really going to do anything to make you well.
And is probably only increasing the number of antibiotic resistant bacteria in your system.
You're correct that food poisoning is caused by a bacteria. But if I recall my Biochem classes, you need sustained levels of antibiotics in your blood stream for days in order to wipe them all out.
Short doses, like when you fail to take your entire prescription, generally make things worse.
My two cents - run what you're doing by your doctor. If she agrees with you, send me your address so I can mail you a buck. ;)
You are 100% correct. Saving antibiotics is a bad idea. Not only do you not adequately treat the current bacterial infection, but you risk future antibiotic resistance. Antibiotics are not one-size-fits-all drugs. You can't just take any old antibiotic and expect it to treat the bacteria-of-the-month. Taking an antibiotic here and there just is not good medicine.
OP, I'm with this poster. Run your plan by your doctor and see what he says. I will bet you at least $1 that he will not approve.
I have a fix that has worked for me and several friends, in cases like this and the flu. It was given to me by a Nurses Aid during a outbreak of the flu.
1. Drink some regular Coke. Coke syrup is included in many boating 1st Aid Kit as it is an anti nauseate.
2. Then eat some Regular PLAIN Yogurt, this has the necessary bacteria to put your digestive tract back on tract. IT MUST BE PLAN LOW FAT (Store Brand is great).
3. Then Gator aid or other sports drink to restore fluids.
I have been using this for about 40 years, and for me it has worked every time.
This is very good advice. I've been an RN for 38 years and over that time I have learned what works and what does not work for cases of GI upset, caused by food poisoning or other illness. (I was a pediatric nurse for about 30 years, so I've seen a LOT of vomit and diarrhea!)
Many folks think they need to drink massive quantities of fluids to treat vomiting and diarrhea, but this will usually lead to more vomiting and diarrhea. Small amounts of Coke will settle your stomach, at least in the early phase. Once vomiting begins, it takes about 3-4 good episodes to get the stomach empty. Gatorade and Pedialyte is my go-to treatment, in small, frequent doses (1-2oz every 15 min). They are lower in sugar than juice or soda--sugar is a natural laxative, which you don't need when you have food poisoning. The idea is to take in little bits and keep it all down.
Once the vomiting stops, you can ramp up the fluids and add some bland solids, like crackers, toast, bananas, rice, and applesauce.
Yogurt is very good for replenishing the intestinal flora, that good bacteria which keeps the bad germs from taking hold in your gut. At least 6oz per day will do it.
You don't need to rush to increase the diet. Give your gut time to recover and don't push it. It can take 3-4 days to feel better after any GI illness.
