OldBlackWater
Jul 21, 2015Explorer
Follow-up: I bought the Roadmaster brake switch from etrailer and installed it above the brake pedal. I ran wires to the front of the car and used an SAE 2-pin cable to connect to the wiring I had already installed for the ReadyBrake LED dash indicator light in the motor home. Works great. It only lights up when the toad brake pedal moves from its resting position, and with the ReadyBrake cable having a couple inches of slack, I could tell it only activated the toad brakes in moderately hard braking situations. Lightly tapping the brakes to get the F-53 to downshift on downgrades was not enough to make my C-Max brakes activate, so I'm quite happy with its functionality.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
