braindead0
Jun 23, 2016Explorer
Chiefchazfaz wrote:So you are putting the transfer case in neutral in order to tow the Explorer correct?
It gets into low as I attempt to take it out of neutral. When I get ready to tow I follow the steps to get the neutral tow light to engage. After towing I follow the steps to take it out of neutral that is when it goes into 4 wheel low.
If that's the case I would suspect loose/bad wiring in buttons used to control transfer case.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
