braindead0
Jun 23, 2016Explorer
Chiefchazfaz wrote:If you can easily access the rear of the panel, I would suggest un-plugging and re-plugging the connection. Generally for electric connections I use dielectric grease however as this is inside the cab probably not all that critical.
Yes that's correct it is in neutral when I tow and when I go through the steps to take it out of neutral it goes into 4 wheel low. But this afternoon it when I got back from our outing it worked just fine. So maybe it is a loose wire somewhere or some other electrical issue.
Good luck!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
