SidecarFlip
Sep 14, 2017Explorer III
The transmission is 'by wire' actuated so holding the shift quadrant in place physically, does nothing.
Being a Ford Family, I'd call Ford in Dearborn and speak to an authorized Ford representative. Having said that, I don't believe you have any recourse with Ford because there are mitigating circumstances, you let the battery drop below 9 volts static charge. That is the level at which the ECM drops out and all systems go into default.
They may offset the repair but I don't believe they will stand good for the entire amount.
Guess thats why I prefer a manual transmission. It has a physical neutral.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
