RedRollingRoadb
Nov 02, 2017Explorer
2015 Focus SE, auto transmission. Bought used from dealer demo fleet. Had the transmission shifting issues and fixed under warranty. No other problems. Put in neutral, wait for the ready message, disconnect battery, remove key and depart. Like driving it. Usual small car road noise but not terrible. Plenty of zip when you want to scoot out.
Installed the Blue Ox base plate myself, toughest part was drilling the 1 1/4 inch holes in the frame/bumper to install the nuts on mounting the bolts. And getting the lard butt up off the floor.
Put a disconnect switch on the negative post as Ford requires disconnecting the negative cable.
Used the NSA Ready Brute Elite tow bar. I like it as no need to run a charge wire to keep a brake unit powered. The toughest part was running the braking cable getting under the car.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
