georgelesley's avatar
georgelesley
Ford Focus towing question
Going over the protocol for setting our 2014 Ford Focus SE up for towing. The owners manual gives clear, good instructions except it is not mentioned whether the ignition key should be removed or not at the end of the preparation.
What is the right answer from those that already tow a Focus?
  • RURBAN1185 wrote:
    Is your 2014 Ford Focus and automatic?
    Yes it is considered an automatic, but really is a dual clutch manual with automatic computer shifting. Sounds complicated, but shifts just like an automatic.
  • Stoney wrote:
    On my 2014 Ford Focus the key may be removed after the battery is disconnected.
    Thanks. That seemed logical to me as well since it is not a mechanical steering lock but electrical.
  • On my 2014 Ford Focus the key may be removed after the battery is disconnected.
  • After I hitch the car and make all the safety cable, electrical and break away cable connections to my 2012 Focus manual transmission car. I drop it in neutral, release brakes and leave the ignition switch in the OFF position and put the keys in my pocket. That is all I need to do. Hope this helps.
Looking for advice before your next adventure? Look no further.25,167 PostsLatest Activity: Oct 05, 2025
