Chaz59's avatar
Chaz59
freezer not freezing
I have small new danby refrigerator, in my tt, but the freezer will not completely freeze. The refrigerator with a small fan in it will reach 40 degrees. Any thoughts on how to get the freezer down lower. Thanks
  • DrewE's avatar
    DrewE
    Explorer III
    It's probably a lot of work, but...if a little fiddling doesn't get things working better, I'd take it out and try running it in a house. If it works properly there, then something in your installation needs work. If it doesn't work well there, exchange it under warranty for one that (we hope) does.
  • You may have to use a small fan to force air over the coils and outside.
  • This is a half size frig, brand new, it is a tite space but looks like there is adequate room on the coils. It is hot outside but it doesn't freeze at nite either.
  • DrewE's avatar
    DrewE
    Explorer III
    This is something like a dorm-style compressor fridge, right?
    The fridge compartment should be able to get below 40, and the freezer section cold enough to at least make ice cubes. My experience with many of these little fridges is that there's a very fine line (if any) between "ice cream stays solid in the freezer" and "milk freezes in the fridge."
    Anyhow, assuming you have set the thermostat control down, I'd check that there's adequate provision for airflow over the coils in the back (if it has them) and that they are not choked up with dust. If there are not coils in the back, the condenser may be more or less part of the outside case of the fridge, and if it's in a tight cabinet, that would hinder cooling.
    If there are coils in the back and they're in the airspace that formerly had the back of an RV fridge and it's hot outside, that could also be a contributing factor towards lack of cooling (along the lines of what jfkmk wrote).
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
