navegator
Dec 10, 2016Explorer
Just a dumb idea, white Styrofoam panels and making an enclosure around the grey and black tanks with a light bulb to maintain some heat, even cardboard should work to make a closure around the tanks and a heat source, just an idea.
I insulated my tanks with expanding foam and placed insulating tubing on the water lines, water tank is under the sofa/bed and the water heater is next to it and all water lines are inside the cabin, only the grey and black tanks are under and exposed, word of caution when using the expanding foam make sure that you build a barrier so that it has a stop, otherwise it will really get out of hand.
navegator
navegator
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
