pointbrze's avatar
pointbrze
Fresh Water Drain Valve Broke
Searched the forums but found that most fresh water drain valves are attached by screws. I cannot seem to find the type that I have on my trailer. Any suggestions on how to remove this one and replace with a newer one? Or am I going to have to replace the whole fresh water tank?
Looking up at the fresh water tank valve:
Looking from the side:
Closer look:
Thanks,
Cindy
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I'm fairly sure that is a common valve that just screws in.
    Worst case it crumbles, and you have to use a thread chaser to clean out the fitting it screws into
    Absolute worst case.. There is an expandable rubber plug you can replace it with, Works great for low pressure installs.
  • skipnchar wrote:
    The base of the valve looks a lot like a bolt/nut base. Have you tried putting a wrench on it? If so it's probably sealed with some lap sealant that may need to be loosened first.
    I will try the wrench, but it crumbled in my hand - hate to see what it's going to do under the pressure of a wrench. Well it has to be replaced anyways. Will GooGone help with the lap sealant? I don't want to scrape or scratch the tank, I fear I might poke a hole in it. :)
  • The base of the valve looks a lot like a bolt/nut base. Have you tried putting a wrench on it? If so it's probably sealed with some lap sealant that may need to be loosened first.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
