I will be spending the winter in one spot and will have city water. Should I empty the fresh water tank or leave somemwater in it? Should I plan to sanitize in tje spring before I head north?
Where are you spending the winter? If you are down south where freezing is not an issue then it shouldn't matter. If you don't use the water in the FW tank then it might make sense to drain it. Regardless of your choice come spring sanitizing the tank makes sense.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
