the_e-man's avatar
the_e-man
Freshwater Hookup Port Question
Hi All,
After getting a new camper last spring, I had to think of a different way to hook up my freshwater hose. The new camper had a universal docking station. That meant I had to run a hose up through a port in the RV floor to hook it up inside a storage compartment. I couldn't seem to get the hose tight enough and had a drip. I think I have solved that. I used one of the flexible hose couplings that come with a water filter and put that in between the hookup and the hose. I also added a few other things like a quick connect and a better water hose. I did a writeup of all the parts I use to hookup my freshwater hose at drinking water hose connections
Wondering what people do to plug the port in the floor. I would prefer not to have mice, ants or other pests come into the camper through that hole. So far, I have just been stuffing a rag in around the hose. Anyone have a better solution?
Thanks
  • I put a 90 degree elbow on before the hose. The hose fills the hole quite nicely.
  • Steel wool will be a better plug than rag that a mice can still gnaw through -- assuming your flooring is not wood, thin plastic, etc .
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
