- camperforlifeExplorerAs others have said, the manual says loosen it in the rain. I have used a pair, right & left for 12 years and have never felt the need to loosen it in the rain. Never quite understood what situation other than snow or ice that would require loosening it.
- jerem0621Explorer IIat least you can remove the sway control if you ever get caught in the snow. Integrated WD/Sway Control guys don't have the option to remove sway control and retain WD like a 'standard' WD hitch can.
I used two friction sway bars on my 31ft TT. Never had a problem. I never adjusted it either. I just bottomed out the on off bar.. then a little more..then I was done. Never had any sway or wiggle.. or anything with two bars.
When I buy another TT it will be a standard WD hitch and two friction bars again... and I will NOT be taking them off in the rain. I did that once while towing in the rain.. let me tell you, if there is a time you need them its when the wind is blowing during a rain storm.
I am a HUGE proponent of sway bar ... or Hensley.. Nothing in-between. The reason is because I want to have a choice with standard WD hitches and friction sway controls.
1) Weight Distribution and Sway Control
2) Weight distribution with no sway control
3) No Weight Distribution and sway control (Ever heard of losing a WD bar? Happens pretty often... with a standard WD hitch and sway control you may lose some WD but you get to keep sway control.)
A Hensley doesn't use friction to control sway.
Thanks!
Jeremiah - mkirschNomad II"how much you loosen it?"
Aren't friction sway controls either ON or OFF? - BedlamModeratorFriction sway devices can be adjusted by tightening the other clamping bolt as the material wears. The handle can be loosened while the device is still connected if you want disable or lessen the affect of the device.
- BurbManExplorer II
Ron Gratz wrote:
The most commonly sold FSC is factory-set to produce a yaw-axis torque of about 500 lb-ft.
Ron, great explanation, and as always, thanks for doing the math for us!
I am curious how you got the above number...is that the maximum value if the handle is tightened all the way? - shum02ExplorerOnly when I'm in snow do I loosen it. In my mind and experience rain/water does not count as slippery. In those cases slow down and drive for conditions, you should not have any issues with a frictions sway control or driving for that matter system if you follow that advise.
- Ron_GratzExplorer
BurbMan wrote:
Some of the friction sway control instructions used to state that the "tension adjustment bolt/screw" was preset to produce a bar friction force of 1100#.Ron Gratz wrote:
That amount of force, combined with an estimated 5.5" lever arm (perpendicular distance from center of ball to line projected through axis of friction bar), would generate a yaw-resisting torque of 1100*5.5/12 = about 500 lb-ft.
The amount of friction force is determined by the tension adjustment bolt or screw located near the bottom of the bar assembly.
Tightening the bolt/screw increases the force. I don't know how much force can be generated in excess of the preset 1100#.
The handle at the top of the bar assembly is intended to turn the friction force "on" or "off". It is not intended to be used for adjusting the amount of force.
Ron - TvovExplorer IIHmm... thanks for the explanation, Ron. I've never tightened my friction sway bar ALL the way, just a couple turns. It just seems like if I tightened it all the way, it would be so tight that the ball connecter on the hitch would just break off. Then again, my TT size and weight is half what my truck is rated for, so I'm not too worried about sway. I'll have to check this out... in the Spring!
- SlowBroExplorer IIISo I have one question: If I must loosen or turn off anti-sway during rain, doesn't that make friction control a bad choice? After all, I'd think the very worst time for a trailer to sway would be in the rain.
- BedlamModeratorI don't worry about rain, but with snow or ice I disable it. In these conditions you should be driving slower so sway is less of an issue than when you are driving at full speed when it is dry. Even in rain, I hope others that are towing reduce their speed too...
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
