GoPackGo
May 20, 2017Explorer
I had the same problem.
Is your fridge in the slideout ???
If so, then you might have the same situation that I had. The flexible gas line located under the slide got kinked when the slide was 'in', which stopped the flow of gas. The solution was to use some plastic ties to keep the line in place and prevent it from kinking. Once we did that, my fridge worked just dandy.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
