Go outside and open the Fridge's outside compartment.. There will be an outlet there, may be a single or a duplex.. Plug in a test lamp (A trouble lamp will do, or any 120 volt test lamp, table lamp, or simple (non electronic) Device, Or if all you have is a radio. it will do) Does it work? YES, next step, NO you have a 120 volt supply side issue.
On the bottom is a small circuit/terminal board, this is NOT the control board,, It has fuses, WITH THE FRIDGE UNPLUGGED check those fuses.. ONE of them is, as I recall, a 120 volt fuse (You can follow wires to figure out which, simple board) the others are 12 volt.
Post results.
When you replace the outer cover..... REMEMBER the Drip Tube on Dometics goes through a vent hole to the OUTSIDE of the compartment.. One possible issue is water dripping on that simple board may have tosted a trace or connection,, This is easily fixed, but.. Why make it happen?
