wbwood
Dec 08, 2013Explorer
Fridge Question
In all the discussion about refrigerator, i've always taken away from the subject that it needs to be level to operate correctly. And having it running while parked and not level can damage it. Ev...
pianotuna wrote:
Hi Chris,
How much time does it take to install?
I wish Dometic and Norcold had this feature built in.Chris Bryant wrote:
Generally, the more level the better, but the object is to keep the boiler area of the cooling unit fed with enough ammonia solution. I was recently introduced to a new safety item which eliminates the danger of off level operation by sensing the temperature of the boiler, and through a reasonably sophisticated algorithm, shutting the power off (and restoring it). The original webite for this product is here, with a website that I did for them- gratis, because I believe in the product so much- at http://healthyrvrefrigerator.com/ (still a work in progress).
