Lerv's avatar
Lerv
fridge removal and replacement
My fridge has died on me, and I am curious, how can I remove it from the coach? Looking at the numbers, it seems to large to fit through the rear entry door https://refrigeratorfaq.com/refrigerator-lock/ . Does anyone have experience here?
Thanks
FYI, my rig is a 1988 Chinook Concourse 18 plus. It has a Norcold 8663, 6.3 cubixc foot, 3-way fridge.
  • Hi—we just did ours and replaced it with a residential model. Have done many over the years. Do you have specific questions that I can answer for you?
  • The shop at the RV store where I work usually takes them out the nearest window. It takes the about 10 minutes to remove a window and about a half hour to re-install it.
    They take the fork lift and extend the forks into the coach, hoist the fridge up onto the forks and back it out. This may be your biggest challenge doing it this way, unless you have a fork truck that is.
  • You can make the frig smaller by removing the door, and sometimes by removing the cooling unit. If that doesn't work, you may have to remove a window. Check to see what your best option is by measuring doors and windows.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
