Hank_MI
Apr 09, 2017Explorer
Cleaning the burner tube is where I'd start. If you pull the tube completely out then tap around on the stack above. Get as much loose rust out of it before reassembly. On previous MH our fridge wouldn't stay lit while driving but was ok when stopped. Did the cleanup I mentioned and worked perfectly after that.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 28, 2026
