Caveman Charlie wrote:
I ordered a new burner assembly which includes the orifice and the burner. Of course it is different and won't go on my propane line because the end is different.
So, I ordered a new line ; which I know it going to be different; because I can't get the original one and even if I did it would have the wrong end on it.
When the new line comes I will try and find someone that can either bend it to fit with a tubing bender or, more then likely, I will have to cut both lines and splice them in the middle with a chunk of hose and two clamps.
(Sigh)
  I had this same issue when I changed mine, I had to cut one end off and reflare the tube end with a new fitting. The tube is Al and is easily bent by hand.
