Gjac wrote:
Caveman Charlie wrote:
I ordered a new burner assembly which includes the orifice and the burner. Of course it is different and won't go on my propane line because the end is different.
So, I ordered a new line ; which I know it going to be different; because I can't get the original one and even if I did it would have the wrong end on it.
When the new line comes I will try and find someone that can either bend it to fit with a tubing bender or, more then likely, I will have to cut both lines and splice them in the middle with a chunk of hose and two clamps.
(Sigh)
I had this same issue when I changed mine, I had to cut one end off and reflare the tube end with a new fitting. The tube is Al and is easily bent by hand.
Thank you for pointing out that it's Aluminum.
Well, after many months I got the fridge fixed. The thing is that I am either working or camping. I don't have very much time in between. So I haven't had time to work on it. I tried ordering another tube that was sold as being the correct one and it wasn't. Now that I had 2 I decided to just throw caution to the wind and start bending it. After about a 1.5 hours of bending it this way and that I was able to find a position that would work without the tube rubbing on anything. Next problem was that you are suppose to put the burner on the tube and then install it and I couldn't do that. I had to put the burner in the hole first and then install the tube. This meant that I could not get a wrench on the fitting to get it tight. I found a cheap 5/8 wrench and cut/broke it to the right length so that I could get it to work in that spot and tightened the fitting. It's in the shed running great right now with no propane leaks.
For a over a month I was buying lots of ice and using coolers. ( that sucked) For another month I had the fridge working but, not on propane so I always had to use spots with electric. Now that it's fall I love being able to park anywhere without needing to plug in so I hope this works. Everyone cross your fingers for me and maybe it will work. Have a nice Day ,,Caveman Charlie.
