BarneyS
Aug 31, 2016Nomad
bluesurf wrote:
Snip...
The vehicle FAWR is 4600, and rear being 9450 for a total of 12,390. NCC is 1660. How do I ascertain out how much of that is the front vs rear axles? My wife and I are ~340 combined, and do not carry much in the front area, so I'm really looking for the overall cab + engine weight and haven't found a source.
https://thormotorcoach.com/media/documents/2000_Four_Winds_Chateau_and_Sport_Class_C_Literature.pdf
Go to a CatScale location and weigh your rig. They are located at most large truck stops.
There are three platforms. You put the front axle on the 1st, rear axle on the 2nd, and trailer axles on the third. In your case you would probably only use the first two platforms. You can weigh any combination of axles you wish.
Just make sure you don't tie up the scales very long if it is busy. Truckers don't mind waiting in line but will get upset if someone ties up the scale for a long time.
Barney
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
