chrispitude's avatar
chrispitude
Front receivers - is there any margin in the ratings?
Hi all,
I'd like to put a front hitch on my truck to make the sharp right turn into my my driveway. However, the front receivers are rated for 500lb vertical and 5000lb pull, and the tongue on my trailer weighs 720lbs.
How realistic is this rating? Because in fact, all front receivers I see have this same rating:
Curt 31078 for 2017 Ford F-350 Super Duty - 500lbs vertical / 5000lbs pull
Curt 31071 for 2017 GMC Sierra 3500HD - 500lbs vertical / 5000lbs pull
Curt 31067 for 2017 Ram 3500 - 500lbs vertical / 5000lbs pull
Curt 31077 for 2017 Nissan Titan XD - 500lbs vertical / 5000lbs pull
Has anyone used a front hitch for low-speed maneuvering (<5mph) into a driveway? If so, what's your tongue weight, and do you remove the weight distribution bars before you do it?
Thanks!
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
