Need-A-Vacation
Jun 20, 2015Explorer
As mentioned, post some weights up if possible.
If you can't, what model bullet do you have? Do you pack heavy, front pass through loaded???
Without actual weights for your set up we can only speculate.
My initial thought would be you need higher rated bars. But, it's hard to say for sure.
Also, it seems easier to state how many chains links are under tension (between the bar and bracket) since the total number of chain links can vary, instead of the loose extra links which it seems like you posted.
The popping and creaking is normal for a DC (Dual Cam) system as is needing to jack the trailer up to "latch" the bars up.
Do you have a round bar or trunnion system?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
