Terryallan
Jun 20, 2015Explorer II
gschindel wrote:
Does seem to drive ok
Wouldn't bags decease the amount of force I need to put on the bars? To me it seems that "lifting" the back a bit with bags would put more weight back on the front??
I can't find anything from dodge saying about what the front should go back to.
No bags will NOT return lost weight to the front. they will only raise the rear. The front will still be light. In fact the bags will remove tension from the bars allowing the front to rise even more.
I'm betting the fact that you transferred 1/2 of the lost weight back to the front. will be all you need. If the truck, and TT drives well, and there is NO sway. You have accomplished your goal. If you still have sway. Keep working at it.
Since you seem to have got it right. Now add sway control. sway control is form those times when you induce sway by doing a emergency maneuver to doge something in the road, or similar situation.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
