Shane549's avatar
Shane549
Front weight transfer
I just purchased a 2015 Laredo 240MK and have a question on whether
all the front end weight should be restored after hitching up.
I weighed the truck before picking up the camper and the weights
are: Steer axle 3160 Drive axle 2560. Reweighed on way back and the
weights are Steer axle 3020, Drive axle 3260, Trailer axle 5060.
Truck weight was with me in it and a full fuel tank. Camper had
1/3 tank of water which is what I usually carry. I know I will be
adding weight to the camper which increase the tongue weight some.
Knowing that should I adjust my bars to transfer more weight to the
front? The dealer told me they set WDH hitches so that the TV sits
the same as before hitching. I said the Ford manual said to split
the difference and they said they never heard of that. I told them
to set it so I have 1 inch of squat in the rear and they did.
Rig towed perfect on the return trip. Thanks
  • Put a Ranch Hand front bumper on the truck and you'll have enough weight on the front to not worry about if the WDH is distributing enough. Then your only real concern making sure you aren't over any axle weights. :)
  • Dealers always setup an empty trailer, and most do it well. However. Having bought 2 new trailers, and let the dealers do the empty setup. I have found you WILL need to readjust the WDH after loading. . It will probably be as easy as pulling another link in the chains. That will usually take care of it.
  • Personally, I would load the camper up and truck as if going on a Camping trip, then reassess the WD hitch adjustments. Several 100 lbs of gear can make a significant impact on weight distribution.
  • If it seems to handle OK then I'd say that's close enough.
  • Know what you mean. I will recheck the manual but I seem to recall
    measure before hitching, measure after hitching and split the difference.
  • Front axle weight restoration varies form one vehicle to another. Some require 100 percent, some require as little as 50 percent.
    Page 200 of your owners manual (link), gives you Ford's recommendation for your truck.
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Feb 01, 2025
