wa8yxm
Oct 03, 2016Explorer III
Several things can reduce frost build up
FANS.. There is a fan/light assembly designed to mount to the TOP of the fridge which I'm told is somewhat effective in reducing frost build up.. It is, however, expensive.. I have two "Computer" type fans on the shelf in front of the fins, one high volume one low, the high one has done a fairly good job of preventing frost build up the low volume one reduced it but alas did not prevent it. (There is more to this story but. Well, the frost left on it's own, I fix the reason why, in theory, tomorrow).
The fans are 12 volt and simply wired to the light circuit.
Next:
Ever stand there trying to make up your mind what to snack on for 5 Minutes.. Make it 5 SECONDS.
Decide before you open the door (And yes I'm guilty though 5 minutes was exaggeration).
Check all seals, Make sure the door closes properly.
Next:
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
