memtb
Sep 27, 2020Explorer
I would consider that quite an anomaly! Generally the higher frontal area above the tow vehicle is responsible for fuel mileage differences!
My opinion may be skewed by the tow vehicle (pick up truck) having a topper, which may have positively affected the air flow across the tow behind camper.
On a slightly different issue, unless extreme, weights are not a significant issue pertaining to mpg. If the same unit is used in a comparison, wind resistance due to increased speed is much more of a factor in mpg than is a few hundred to a thousand pounds of carry weight. Many folks will not fill their fresh tanks prior to travel. I would dare to suggest that under identical situations, the difference in fuel mileage is near immeasurable!
memtb
memtb
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
