Do folks have a preference? I've always used seafoam. On my small engines.. (weed whacker, lawn mower, snowblower etc) I will be starting the RV every month during storage, and hopefully moving it ...
All my small engines get E0 (non-ethanol) gas. After I drain the tank and run the carb dry, I put some 2-stroke mix in the tank, run it through the carb, then drain the tank and run the carb dry again. The 2-stroke oil 1) has stabilizer in it and 2) I figure it keeps the carb gaskets from drying out.
I had to tear down and clean son-in-laws weedwacker carb this spring after he let it sit all winter with E10 in it. Coincidence?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
