suprz wrote:
I will be starting the RV every month during storage, and hopefully moving it a few feet forward and backward . .
The worst thing you can do is start an engine and only run it for a short time before shutting it down. The engine will not burn off all the water and acids that are generated during a cold start and the initial run up to operating temperature. The exhaust system will rust out sooner too. You absolutely need the oil to come up to operating temperature. Water is a by product of the combustion process and doesn't get burned off unless everything gets good and hot.
The old time rule is that short trips of less then 5 miles are hardest on a vehicle. I believe that to be true. My last vehicle (Honda Element) had 185,000 miles on it when I traded it and it was running like a top. Never did anything to it but basic maintenance. But I drove 30 highway miles each way to work every day.
Just my .02
Tim
