JamesBr
Jul 09, 2013Explorer
You have a later model ford, so the filler neck will let you use the high flow truck pumps. You have two options for convience. You can get the GS PFJ RV plus card which is a net 30 fueling account. Or you can activate pump start on a standard PFJ RV card. Pump start will allow you to start the RV or Truck pumps without a CC, and then go in an pay. I have both cards now and use them depending on what I am doing.
If you do use the truck pumps, make sure to pull up after you fuel, they can recall the proper transaction when you go in to pay or get a reciept after your pre authorization. I have never had issues with the truckers running this way.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
