opnspaces
Oct 08, 2021Navigator III
I can think of three options.
Can you put larger items in the back like the milk carton that can't fall through? That would block and keep everything else from falling through as well.
Not free but try these to make a back wall on the shelves. Clamp them upside down on the back of the shelf and screw a piece of cheap 1/2 pine or even a cut off piece of clear plastic on the back. The idea is to put a back lip that runs across the shelf so even if it slides forward things can't slide off the back.
Amazon
A bit uglier, buy a sheet of insulating foam at Home Depot and cut to stand on end and fill the gap between the door and the shelf. Then put the foam sheet into the refrigerator and close the door when traveling.
Amazon
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
