SDcampowneroper
Nov 17, 2017Explorer
Yes! At high altitude low atmospheric pressure results in a too rich combustion resulting in a ' flame out' . You will hear and see an attempt to light. Your regulator output pressure or orifice size needs to be reduced to match altitude. When it does light a soft quiet light with a lazy yellow flame shows a too rich mixture. Soot would be apparent.
We have had the obverse effect when going to sea level, the furnace would 'flame out' from too much air. When it did light, it roared like a jet engine, so-- I restricted the air intake a bit with my fingers until I found the sweet spot. then covered that much with tape.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
