brholt
Nov 18, 2017Explorer II
If you the fan comes on and then turns off without lighting one potential problem is the "sail" switch. This is a switch that allows the gas to flow if there is sufficient air flow. At high altitude and running on batteries you may not be getting enough air flow.
If this is the case you might have the switch adjusted.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
