bigblueok's avatar
bigblueok
Furnace propane ussage
We have a 2012 Cougar 327RES fifth and last night I had to stay in it to prevent the water lines from frizing since it got down to 24F. I used what I thought was a full propane bottle and this morning I looked at it an the frost was about 1/2 down the bottle. I'm assuming that the frost line is where the gas is.
How much gas does the furnace normally use?
  • Yes, it does sound about right. The furnace will really use the propane. We normally only use ours for a fast morning warm up and use an electric ceramic heater with a thermostat setting for overnight and continuous heat.
  • That actually sounds about right, The bottles are never "topped off" and the furnace uses a great deal of propane when on all night. We plug our RV in and run a small electric heater at night (or all day if the weather demands it as we are still planning on going camping this winter), but why don't you just drain your water lines and blow them out. Cheaper than propane.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 16, 2026
