TurnThePage's avatar
TurnThePage
Furrion Instant Hot Water in Cold Weather
I've been couch surfing various new RVs. Grand Design has switched some units to tankless instant hot water heaters. It appears that they are required to be winterized and NOT used in sub 39F conditions. That's crazy!!
I would consider that a show stopper and would likely purchase a different brand. Is anybody familiar with this stuff? Can you retrofit a good old 6 gallon water heater in? Maybe switch to a different tankless brand?
I'm just trying to learn as I near that next big purchase.
  • wanderingaimlessly wrote:
    Tankless water heaters by design have a limited amount of time to warm water. the heating unit only hold a quart or so of water, so water passing through it is only in the heating coils for about 20 seconds for a faucet discharging less than a gallon a minute. Usually they warm the water about 50 degrees by design at their designed flow rate.
    If the incoming water is 70 degrees, then it heats to 120 which is fine, but if the incoming water is 40, then the warmed water only has time to reach 90, which is lukewarm at best.
    Another issue is water pressure.
    If you read the literature on home tankless, they will say not to have water pressure above a certain limit as it pushes the water through too fast to get hot. They want a pressure reducer installed.
    Tankless sounds nice, but I would not buy one if I was going to be in cold weather.
  • Seems like there ought to be some way of installing a small electric heating element near the area that's prone to freezing - which would at least help when you had AC hookups.
  • Skibane,
    I replaced the cold air return grill with a twin window fan. It pressurizes the heat ducts enough to prevent freezing for me. It draws 27 watts on high. I have it connected to a manual thermostat.
    Before the fan I had used a 1500 watt heater inside the cabinets. It was not enough to prevent plumbing freeze ups.
  • My 5er has a Girard tankless water heater which has an adjustable temp control which allows water temps up to 131* and a built-in thermostat that starts the burner whenever the heat exchanger falls below 38* and heats to 58*. This works as this past Dec. we camped with overnite temps to 9* with no problems. Suggest the op's friend check his wh docs to see if his is so equipped.
    I'm betting this is the main reason. They don't want to field calls claiming the water heater isn't working right.
    Witt no water flow, that must be a really short burner run-time.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
