IHnutz's avatar
IHnutz
FW trailer level when towing
I'm sure this has been discussed before but?? How far off level is acceptable for the trailer to be when towing? With the trailer hitched to the truck on a level spot it sets about 2 1/2" to 3" high in the front. The truck is a 4x4 so it sets high from the factory. The pin box is raised as high as it will go. I am using a goose-neck adapter (no flaming about this, it is what I have) with ball mounted permanently to a plate under the 8' bed. The adapter is adjusted to it's lowest position. There is about 4" to 5" between the frame of the trailer and the bed so there is no more room to lower the front of the trailer.
Your opinions - is this a serious problem or just a fact of life I have to live with?
