lawnspecialties's avatar
Mar 08, 2016
G Rated Tires / Not Max Pressure
In another thread, we're discussing if the dealer gave me the proper valve stems for my G614s. They're certainly not the typical metal stems. The dealer is 260 miles away. So I'm fixing this thing here. I will be discussing this with them tomorrow for sure.
But if these are 100 psi rated stems, how much of an issue is it to just keep them and run 100 psi? I know I don't need the full 3750 lb. rated capacity at 110 psi. The camper originally came with E rated tires. I just wanted the G614s because the speed rating was 75 mph and I experienced a TowMax failure one trip and never want to go through that frustration again if possible.
What's the drawbacks of running these at 100 psi?
  • I ran GY G614's on my HR...recommended psi was 110 and 4 years later, they still looked as good as new... If I were the OP, I would replace the rubber valve stems with the metal one's. ...I wouldn't use rubber valve stems on an E or a G rated tire..I ran Michelin RIB's on another 5er and used metal valve stems in them also, at 80 psi..just a more robust valve stem over the rubber
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
