STBRetired
Dec 12, 2018Explorer
You also need to know where the gas port is tapped off your RV system. If it is before the regulator, then you just need a different hose with the correct fitting. If it is tapped off after the RV regulator, then you need to remove the regulator from the grill. My gas port is after the regulator, so I have 2 hoses for my Weber Q. One with a regulator on the end to hook to 20# tanks, and one with no regulator that plugs int gas port. The regulator that was originally installed inside the grill has been removed.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
