ScottG
Dec 12, 2018Nomad
The port is low pressure so you will need to remove the existing regulator on Big Red and install either a hose or a quick disconnect for one.
I've done this to all my stuff (fire pit, stove, BBQ) and it works great! Most regulators are simply screwed on with normal pipe threads - usually 1/8"NPT. I have 25' of gas hose with QD's (2X10', 1X5').
This QD is on my BBQ:
Being cheap, I simply bored and threaded the inside of this QD to fit the 1/8" NPT on my grill.
One caveat, there are two common quick disconnects out there for propane and they dont play with each other.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
