troubledwaters
Dec 13, 2018Nomad
DutchmenSport wrote:My Coleman stove adapter works just fine off the propane connector. clicky
All I can say is, "Good luck." That hook up does't play nice. I've been trying to get a Coleman camp stove hooked up to the same gas port. I was able to finally fabricate a line that had both end connections to match. I purchased the Coleman regulator separate and cut the regulator part off and used the connection to the stove. I then cut the rubber hose that had the connection for the trailer.
End result? didn't work. The pressure regulator on the camper didn't match the required pressure on the camp stove and the flame blew out at the slightest puff of wind. The camper produced pressure too low for the stove. So, I'm back to using the 1 pound propane bottles from WalMart...
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
