portscanner
Dec 14, 2014Explorer
Sprink-Fitter wrote:
So it works perfect when you are not using it?
Absolutely!
DSDP Don wrote:
Open the oven and use a small piece of sandpaper and lightly sand the thermocouple. This cleans the rust off. It's the little metal tube that is in the path of the pilot light. The pilot heats the thermocouple, which tells the gas valve to open and stay open. Make sure the thermocouple is in the path (middle) of the pilot.
The other thing that might be occurring is that as the oven temp cycles and the burner relights, it's blowing out the pilot. Make sure that any kind of shroud around the pilot is positioned properly.
Will try that this week.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
