wa8yxm
Jan 05, 2015Explorer III
If the pilot lights and holds normally (mine is hard to light) Let it burn for 2 or 3 minutes and check it again, if it's still burning your options are:
Loss of pressure
Bad control valve (Thermostat) it contains a safety device that senses the flame of the pilot.
I usually heat mine well, then fire the main burner, then it holds till time to turn it off.. I do not use it often, (Every time I make Cheesecake) but I do use it from time to time, Last was 12/17,, Took the cheesecake to the Pot Luck on the 18th (Glad I decided to do that, things happened on the 18th and I was pressed for time, Unlike so many things you can make in advance, Cheesecake MUST be made in advance, so all I had to do was take it out of the fridge and go).
Worked well.
Loss of pressure
Worked well.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
