jplante4
Sep 26, 2018Explorer II
You shouldn't be smelling propane. Make a manometer out of clear tubing. About 3 feet will do. Fill it halfway with water and make a U, stick it over the spud on the cooktop burner, turn on the gas, turn on that burner. The water should go up in the tube about 11 inches. Tape the tube in place and mark where the water level is. Turn off the gas at the tank and watch the tube. If it goes down, you have a leak.
clicky
clicky
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
