John_Wayne
Sep 26, 2018Explorer II
I don't think you will get 11" from the burner tube It your stove top is like mine it has a additional regulator for the stove top that reduces the pressure less then 11". So take the reading from the tube that goes into this regulator. Also if you are going to be setting the regulator pressure some else running on gas should be on like the furnace.
If just checking for a leak you can use the burner tube for a leak test it should hold pressure for a period of time like in minutes. Do some You Tube research on making and testing.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
