Old-Biscuit
Sep 26, 2018Explorer III
11" WC...that is 0.4 psi
Leak down test.....
Hookup manometer to a stove top burner
Open propane service valve
Open burner that manometer is hooked up to...let pressure stabilize
CLOSE propane service valve
Open another burner knob slightly/slowly and drop manometer to 8" WC then close it
3 minutes ....then check if manometer reading has dropped
Low pressure system only needs 3 minutes to detect leak down
Leak down test.....
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
