SGTJOE's avatar
SGTJOE
Explorer II
Feb 03, 2017
GEL Coating
Are all fiberglass RV's Gel Coated?? If not what year did they stop using the Gel Coating? Tired of the Gel Cracks.
  • Thanks for the replys. So which MH's have the best Gel Coating?
  • Non-gel coat sidings are typically called filon, and show fibers. They are hard to match in repairs...the repair looks smooth compared to the siding. Gel coat does not typically crack....but I suspect that there is a quality difference amongst gel coats...some thicker than others.
  • I dont think the vast majority of fiberglass RV's have cracks. Mine doesn't.
  • Gel coat is the first material sprayed into the mold for fiberglas parts. Without it you would see all the glass fibers.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 05, 2025
