Colorado__5's avatar
Colorado__5
General Inspection Checklist
When I take my car in to the shop they run it through a 20 some point inspection and tell me everything that needs to be addressed or repaired. I'm new to RVing but would assume they do the same for a MH when it's brought in.
When a dealership takes in a used MH they claim they run it through a x number of points inspection before reselling it.
Does anyone have or know of a checklist or inspection list that the pro's use to evaluate any issues with a MH?
I will be taking possession of a 2004 Winnebago in a few weeks and I want to run it through the paces when I get it home to see where I'm at.
Any thoughts or ideas would be greatly appreciated.
  • One last thought since your up in Snow country, and it's winter.
    You could check the area where it's located for a Loves or other travel stop type location in the area. I know loves will do your oil in most cases and does offer a quick safety inspection service.
    It may be available and give you some peace of mind.
    Happy motorin
  • Update.
    Found a diesel shop on the way back to my AO that will do an oil change for me. If I decide not to do it myself. I'm fully capable I just don't like changing the oil in cold weather.
    Will checking the temps on the tires truly give me a since of how they are holding up? I have a laser temp gauge. And that would really give me a good peace of mind if I'm able to monitor the state of the tires.
  • I would either have a tire shop do an inspection or read up on what to look for as far as age damage is concernedor check and see if there is a youutube video on the subject.
    You seem to have a handle on the oil but remember to have the shop do a test on the coolant and drain the old windshield washer fluid.
    As far as a comprehensive PDI type of check list, there are several PDIs available on line. For the most part the inspections are easy to do and a mobile or shop tech is not needed.
    Keep checking back here for anything you have questions on.
  • This diesel shop deals in heavy duty trucks. Do you think they would be able to do a good tire inspection?
  • Colorado #5 wrote:
    Update.
    It's not "oh, I checked the temps and there won't be any problems" kind of fix. But, if you are just trying to get the RV home so you can have the time to really go through everything, etc., then it can help you get through that one trip. If one or more tires show excessive heat, then you need to stop driving and get them replaced immediately. If they are all within a good temp range, then you can check for new cracking, separation, etc., and make a judgment call about finishing the drive home before getting new tires.
  • toedtoes wrote:
    Colorado #5 wrote:
    Update.
    Yep... That is exactly how I interpreted that idea. Just a tool to get me home or help me realize I need new tires before going any further.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
