Colorado__5's avatar
Colorado__5
General Inspection Checklist
When I take my car in to the shop they run it through a 20 some point inspection and tell me everything that needs to be addressed or repaired. I'm new to RVing but would assume they do the same for a MH when it's brought in.
When a dealership takes in a used MH they claim they run it through a x number of points inspection before reselling it.
Does anyone have or know of a checklist or inspection list that the pro's use to evaluate any issues with a MH?
I will be taking possession of a 2004 Winnebago in a few weeks and I want to run it through the paces when I get it home to see where I'm at.
Any thoughts or ideas would be greatly appreciated.
  • RV's and Motorhomes are not sold, serviced or warrantied like vehicles. Nothing in your experience with vehicles is directly comparable to how RV's are managed and serviced.
    It is much closer to how a home is warrantied and serviced.
    A motorhome has two separate systems warranty wise.
    The chassis, motor, transmission and running gear are usually warrantied and serviced by the company which built them and sold a bare chassis to the motorhome manufacturer. You see a lot of motorhomes at Freightliner dealerships, service outlets. The motorized mechanical aspects of the motorhome are usually dealt with quicker, easier and more efficently and more cost effectively by a big truck dealer/ repair shop. They have mechanics trained to deal with those systems, and many do a good bit of RV business. Diesel pushers seem to have less issues dealing with the truck companies than gasoline powered Class A units which often have to find a Ford dealer who also works with heavy Ford trucks.
    I've been to several dealerships which sell a lot of Class A units, both gas and diesel powered, who do not service any motor/ chassis related part of the rig beyond an oil change. And overpriced at that.
    The 'coach' is warrantied by the company which build the coach - Monaco, Thor, Winnabago. However only the 'shell' of the body is warrantied by the manufacturer.
    The fridge, the furnace, the water pump, the sink facuets, the AC's, the TV, the stove, the microwave, etc, - are all under their individual warranty from the company which built them and sold them to the coach manufacturer.
    This is like a home where the home builder does not warranty the 'appliances'.
    A good RV service facility does have people familiar with most of the major RV appliances and has relationships with the companies so that they can get parts and warranty work done if applicable.
    A special note on tires - as mentioned above.
    RV tires almost never need to be replaced due to tread wear. Forget everything you learned about tires for vehicles.
    The vast majority of RV tires 'age out' not 'wear out'.
    The main reason to watch tread wear on an RV is for overloading, under inflation, etc patterns of damage.
    It is important to know when each of the tires was manufactured. I would not consider any RV tire over five years old 'safe' on the road.
  • You might be able to find a dealer that will do an inspection for you...at a price. Personally I would do it myself, which you should be able to do. As was mentioned a lot can depend on how long it's been sitting unused.
    The roof is one thing that needs to be checked thoroughly for any leaks, holes, tears, etc. Then things like the house water pump, and associated water lines. Then check for working water heater, refrigerator, stove/oven, shower and shower enclosure, furnace. Then check the condition of sewer lines, holding tanks, and hoses. And of course all the mechanical functions of the motor/chassis/transmission and associated parts, i.e. water pump, alternator, battery, brakes, etc.
    Good luck, and come back and let us know how it has all worked out.
  • OK different set of issues.
    How long has it been sitting? If a year or more, immediately have the oil and possibly other fluids changed. Check the date codes on the tires,
    if 5 years old or older, if possible change them, if not go slow on your way home.
    These items I would try to do before leaving.
    Basic safety items as for any vehicle, lights, horn, wipers etc should all be checked.
    All of this is in addition to the PDI type list covering the house areas of the unit.
  • sorry... I guess I should have mentioned that this MH is gifted to me. So I will take it however I can get it. I do know it runs. I do know there a lower miles on the tires and for the most part in pretty good shape. Its the stuff I don't know that I need to inspect. If that makes any since.
  • Hopefully you've done all the inspections and checks with a fine-toothed comb before you ever actually gave them any serious amount of money. Once they have your money, you are reduced to relying on the good will of the dealership to have problems addressed. Not good.
    A salesman eager to make a sale will tell you many things, some of which may be true. And maybe they sidestep the truth by telling you they "run it through a x number of points inspection before reselling it", but don't elaborate by saying they don't necessarily fix things they found wrong.
    There are several posters on here who have a PDI(Pre Delivery Inspection) list of things to check. I'm sure some of them will stop by with their help.
  • Many dealers "checklist" is primarily relegated to visual appearance to ensure they can sell it, and checking your wallet.
    There seems to be a tendency by many in the industry to wait until they have a sale to prep and inspect/repair units.
    Several people on here have PDI list, I'm sure one will be along shortly to offer one, you should find that helpful.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
